We have ID fan equipped with 2000kw, 207 amp motor which is controlled by Siemens perfect harmony drive. Normal operational current is 110 amps and speed is 810rpm. We are facing a problem that drive amperes and speed suddenly start to vary from 75 amps to 160amps while speed varies between 800 and 830 rpm. I checked the drive set point reference which is quite stable in those moments.
To normalize the system we have to reduce the set point reference to minimum 200 rpm and increase again up to required operational level. Everything then becomes normal, No variation in speed or amperes. If we will not exercise this practice, drive will continue this variation for hours. I believe to exclude mechanical or process problem as system becomes absolutely normal after this practice. This phenomenon is happening once or twice weekly.
Thanks for any help
Fiaz Ahmed
Thanks for any help
Fiaz Ahmed
