Is there a component or technique which will allow me to vary the the thermal resistance between two parts?
I want to control the temperature of the first part by changing the amount of heat transferred to the second part. The second part is maintained at a colder temperature than the first.
It can be a mechanical, pneumatic or electrical control.
The only thing I have found in google was a couple of heat pipes used in satellites. They were very expensive.
TIA
TIA
