UtilityLouie
I have a large heat exchanger with steam on the shell side and 30% glycol solution on the tube side. My big question is:
Can I pump a variable speed pump to this heat exchanger or is there some minimum flow I need to maintain?
I am planning on pumping in parallel (two 1800 GPM pumps, both variable speed). This is a somewhat critical system, so I wanted to have some redundancy without 100% back up. Would there be a problem with just having one pump running?
I know that with a variable speed pump there will be a minimum flow it can provide, but are there special precautions I need to follow to make this system work.
Any suggestions would be appreciated!
