methylester
- Mar 21, 2011
- 2
I'm working with a manufacturer to size a heat exchanger that will be used to condense water vapor that is being extracted from a mixture under vacuum. The vapor is also being condensed under vacuum. For the sake of round numbers, it'll be under about 29.5" Hg of vacuum, at which point the saturation temp is about 60F. We'll be using an hxer with a cold side at about 40F.
His sizing software only works with a minimum pressure of 0.5 psig. At this point, the saturation temp is about 214F. So to get a rough analogy, I suggested that he just plug in an hxer cold side of 194F, to maintain the same 20 deg difference between the saturation temp and the hxer cold side.
What I'm not sure how to compensate for, though, is the difference in density of the vapor. The mass flow rate will be the same either way. But at 0.5 psig, you would have much denser vapor moving more slowly through the hxer, while at 29.5" Hg of vacuum, you would have a much less dense vapor moving more rapidly through the hxer. This has got to have some effect, but I'm not sure how to figure out what that effect is.
Anybody know of a method or rule of thumb to figure out how to approximately compensate for this difference?
