jrwchem
Chemical
- Feb 12, 2006
- 28
We have a storage tank that will be filled via truck deliveries. The truck will be pressurized to 20 psig with N2 to offload the inventory into the tank. I would prefer to use a pump, but the client prefers N2 offloading.
A pressure regulator is designed to provide a maximum N2 flow of say X lb/hr.
Per API 2000, it is wise to consider vapor blow through for vent sizing.
My initial thought is that the tank relief/vent must be sized to handle X lb/hr, since this is the maximum flow the upstream PRV can handle.
However, it has been suggested that a transient case be considered, in which we imagine the truck is empty and pressureized to 20 psig, and the inital flow of N2 from the truck to the tank is considered. It turns out you can get quite an inital "woosh" of flow, which results in original vent being quite undersized. This would be a temporary situation, which would only appear to happen if the truck is filled with N2, blocked in, and then the valve is opened suddenly.
Any thought or comments on the credibility of this case? Any suggestions?
thanks.
Jonathan
thanks.
Jonathan
