Valid Hole Wizard database
NL8
633
Anybody seen the error in SW when you go to use a countersunk or counterbore hole and had the system tell you "No valid hole wizard standards database found.
Joe Hasik, CSWP/SMTL
SW 08 x64, SP 4.0
SW 09 x64, SP 0.0
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
NVIDIA Quadro FX 4600
Had that once last week, just before quitting time. Problem has not re-occurred since re-booting the following morning.
[cheers]
I'm only having it on the counter bore and counter sunk holes and it's across all eight machines. Worse still, I can't find a single setting where I could point the d@MN$ program to a different, possibly correct, location.
SW 08 x64, SP 4.0
SW 09 x64, SP 0.0
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
I didn't get as far as selecting a hole type. The Hole Wizard simply wasn't found but I had the same error message.
Have you tried repairing or re-installing SW on one machine (or the server?) and thereby replacing the database. I assume you are all using the same networked database?
[cheers]
WE are all using the same networked database, my VAR sent me a new copy of the holecallout.txt file, but that didn't help.
SW 09 x64, SP 1.0
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
Joe, Is this happening with SW2009? Do you think there's a conflict having both SW2008 and SW2009 installed on one computer?
Best,
Colin Fitzpatrick (aka Macduff)
Mechanical Designer
Solidworks 2008 SP 4.0
Dell 490 XP Pro SP 2
Xeon CPU 3.00 GHz 3.00 GB of RAM
nVida Quadro FX 3450 512 MB
3D Connexion-SpaceExplorer
Colin,
I was due to update my sig, we're running all 2009 now.
CBL,
Tried the reinstall, didn't help. Tried my VAR's second set of solutions, didn't help.
SW 09 x64, SP 1.0
Dell T3400
Intel Core2 Quad
Q6700 2.66 GHz
3.93 GB RAM
