Vacuum level required in ASME code during the secondary steelmaking ? 1
stanislasdz
Materials
FR
Is there any level of vacuum required by the ASME code during secondary steelmaking ?
Thanks in advance
stanislasdz;
No, because this is a process detail step that is not under the scope of ASME B&PV Code.
Thanks metenger
Is there any other specifications witch required Vaccum level during secondary steelmalking : API, RCC-M, KTA .....
stanislasdz;
Vacuum requirements for secondary steel making, regardless of end use, are between the Purchaser and the supplier.
As I understand the rules, the ASME piping code only permits materials that meet the steel-making requirements of ASTM specifications.
I believe that your vacuum requirement is indirectly necessary in order to produce steels to ASTM requirements
Only "fully killed" carbon steels (e.g. ASTM A106 - GrB)are permitted in certain applications.
