MiniMe4Eng
I am reading this website
and it says these
Inmy case the membrane is going to be Redguard
Are the above correct ?
and it says these
If you’re looking to set tile over a membrane, you typically shouldn’t use a modified thin-set mortar, as the drying process takes far longer than unmodified thin-set mortar. This is due to the mortar being sandwiched between 2 impermeable materials, being the membrane and tile, which does not allow for fast drying. The moisture can’t escape, so it may not cure properly.
With standard modified thin-set mortar the Tile Council of North America says it can take from 14 to more than 60 days to cure properly. In this case, an unmodified thin-set mortar would be best suited, as the mortar is able to properly hydrate and cure faster (typically within 24 hours).
