So the jist of the issue is that I am using a 1 oz. trace, approximately 7 thousandths wide and .5" long to supply a very short, high current (150A to sometimes 500A, 1V or less) pulse to a reactive multilayer to start a reaction. The problem is that sometimes, the trace "blows", charring nearby soldermask and creating a disconnect. The circuit is designed such that the current must pass through the thickness of the multilayer to reach ground.
I have current pulse properties that will never cause this blowing, but also be intermittent in starting the reaction.
I have current pulse properties that will always ignite the reaction, but sometimes blow the traces.
Some people have suggested I look at fusing requirements, but since most people assume a certain frequency above 0, or even DC, this analysis and prior work doesn't really apply to us.
Other things I have started looking into have been inductance when the reaction starts, potentially causing a momentary open circuit, which would cause arcing.
Any ideas on other resources to look into regarding high current pulsing of PCB's, especially those with Metallic Cores, such as Aluminum, would be fantastic. Thanks.
