Hi,everyone
I got a question about the using of command 'CYCLIC'. In my model, there are two types of element,SOLID95 and SHELL93. I used CYCLIC to configue the model as a cyclic symmetric one. But after solution, I found a problem that at the share line of the two elment type, the meshing did not connected, there are two nodes at the same location.
So I wonder whether it is impossible to use CYCLIC with mixed element type.
Thank you !
Rock
Thank you !
Rock
