pewterrose
Hello all,
I am FE analysist but somewhat of an ASME BPCV Sec VIII novice, and have begun course work for learning Div 2. I am trying to invoke Div 2 Part 5 in accordance with the Mandatory Appendix 46 of Div 1. When doing so, I am unsure how much of Div 2 I should be following. I assume all it of unless otherwise stated in the appendix of Div 1. E.g. my report should have all items listed in 2.3.3.3 that apply to my analysis and, the analysis should be in accordance to 5.2.1.2 when dealing with complex geometry. But, I should use a beta of 3.5 when using the elastic-plastic stress analysis method. Is my assumption correct?
Thank you all for your consideration on the topic.
