CoolDude003
hello all,
I would like to know if filling a hose with water and then adding air on top of the water to increase pressure would work. I believe its the same theory as a air over hydraulic pump which can get 100 psi of air pressure to create 10,000 psi of oil pressure.
I attached a very professional photo
of the basic idea.
1. open water supply and opposite end of hose until it is completely full with no air in the hose.
2. close opposite end and then water supply.
3. open air supply until water pressure increases to desired test pressure.
4. stop air supply. release pressure at opposite end of hose.
Would this work? Any links, standards, procedures, examples, special equipment, anything at all would be fantastic.
Thanks for reading!!
![[pipe] [pipe] [pipe]](/data/assets/smilies/pipe.gif)
