I'm probably missing something obvious here, but why is there such a difference between actual and "calculated" pump curves? By that I mean that I made a random pump selection and had the software generate curves for 1750 RPM and 1225 RPM. I then wrote down several data points from the 1750 RPM curve. I had to "eyeball" them, so they are not exact, but they are close enough for my question. I took those data points to a polynomial regression calculator. A quadratic wasn't close enough. A cubic was probably good enough, but I went ahead and used a 4th degree polynomial.
I obtained an equation and graphed it. It very closely matched the manufacturer's pump curve for 1750 RPM (which is where I obtained the data). So now here is my issue. I applied the pump laws relating head and RPM and generated a curve for 1225 RPM. It is quite different from the manufacturer's curve. They start out similar but they become increasingly different as the flow increases.
What am I missing here? What is causing the difference? Attached are graphs from the pump selection software and the ones I generated.
Thanks for your feedback.
