Hi everyone,
I'm an Instrument & Control engineer, I'm currently selecting 2 Control Valves that will be installed upstream two SKIM Tanks (two separate lines), hence we will control the amount of water (with 450 PPM of heavy crude API 12 oil) entering the tank.
The control valve will be a 20" Ball Valve (Fisher V150)
Due to hydraulic restrictions inside the tank when it's clean, pressure drop in the control valve would be too big for a regular control valve to work without risk of cavitation, we have some alternatives such as installing restriction orifices but that's not an option here due to the distance to the tank. Downstream the control valve we have a 24" ball valve, we're evaluating using this valve as a restriction so the control valve wouldn't have to provide the required pressure drop by itself.
This ball valve would be adjusted to a 40-50 %open position and would work like this for about 1 year until the tank starts to get clogged again (this is expected)and the operator would adjust the valve position depending on the desired pressure drop in the control valve, until it's fully open. After 5 years the tank will be cleaned again and this process repeats.
I would like to know how much this service could affect the valve materials (ball specially)? do you have experience in a similar application?
Expected Process conditions:
Flow rate min: 357840 barrels per day
Flow rate normal: 511200
Flow rate max: 630000
Temperature: 145ºF
Specific Gravity: 0.982
Dynamic viscosity: 0.45
Thank you in advance and sorry for my rusty english.
Temperature: 145ºF
