User parameter sublist
Arpad_Jacso
Computer
HU
Is there any way to set a user or renamed parameter sublist?
in script? the parameters do have a property: .Renamed =True/False
regards,
LWolf
It doesn't work:
Set part1 = CATIA.ActiveDocument.Part
Set parameters4 = part1.Parameters.Renamed = False
"Object doesn't support this property or method"
what is it you are trying to achieve?
your syntax is wrong. you can check if the parameter is renamed and then do something based on that assertion:
if part1.Parameters.RootParameterSet.DirectParameters.item(1).Renamed then
Do something​
else
Do something else​
end if​
regards,
LWolf
I have a part with tons of parameter, and I would like to add some via macro.
The goal to add the 'userparm.1' parameter and a round formula. To load the whole parameterset is very long, and I would like to set a user sublist (or renamed sublist) to decrease this load time.
Set parameters4 = part1.Parameters '-------------> this should be a renamed sublist
Set realParam4 = parameters4.CreateReal("userparm.1", 0#)
Set relations4 = part1.Relations
Set formula4 = relations4.CreateFormula("Formula.250", "", realParam4, "round(10*userparm.2)/10")
No, I don't need new subset, I need a sublist for my user parameters
I don't know what to write instead of 'renamed parameters', or I don't know if exists anything like that.
Set parameters4 = part1.Parameters.SubList('renamed parameters', False)
