Hello!
I have a question regarding to the use of command SECOFFSET in connection with element SHELL181 that I use for linear structural analysis.
I'm using this element to model shell with few layers, but I need to offset nodes from midplane to the top or bottom of the element.
The problem is that the results of the analysis don't change no matter how much (option USER) or where (TOP or BOT) do I offset nodes.
Does anyone know where problem is. The results should change because moment of inertia changes.
