gww
- Dec 20, 2004
- 4
I have an application that uses thyristor power controllers to heat up a "melting pot". The supply is 415v 2 phase that is fed through a stepdown transformer giving a secondary voltage of 240v centre tapped. This is fed to thyristor power controller which has a resistive load . If a wire is broken @ the o/p of the thyristor and shorts down to earth i need to detect a current of 30mA or more and "trip" out the supply. I have tried using an RCD but this does not work. Anybody any ideas please?
