Thank you DekDee. I am actually a Piping Designer, with Navy Submarine experience and have been in the submarine overhaul/new construction piping and mechanical field for over 40 years. You are quite correct with your summation of using and verifying the required gap, but what I am suggesting here is a change to the paradigm. If the welder/Inspector verifies installation of the gap-a-let and the joint is say, marked in a certain way to indicate its use, then use of the gap-a-let could quite possibly reduce the amount of time currently required to fit-up a socket welded joint. When you make thousands of joints in one product, time is money, and a lot of it.
And thank you moltenmetal for your observation concerning the use of RT to validate a socket welded joint, where RT is not commonly used to NDT a socket weld joint.
We have to trust our Welders and Inspectors to “do the right thing”.
Commenter’s, please help me stay on track with objective quality evidence as to the value in using the Gap-a-Lets. Has anyone out there witnessed a systemic failure after using Gap-A-Lets? Has anyone done a cost comparison in using/not using Gap-A-Lets for piping system installation? Etc.
Thanks to the entire community for your input; it all has value.
