From this site and other sources, I've come to understand that semiconductive screens in cables are generally used in medium and high voltage transmission and distribution applications. There they reduce uneven capacitive voltage distribution by providing a relatively low impedance discharge path, rather than relying on an insulator to be perfectly distributed. The semiconductive layer is less susceptible to cracks and voids and therefore maintains a more consistent admittance. The trade-off for the reduction in voltage stress in insulation is that you get some additional losses through the semiconductive layer. Please correct me if I'm wrong.
What I want to know is what happens when you use these cables between a VSD and a motor? The Olex Type 241 cable, for example, is reasonably popular in mining environments, and it's possible that it will find its way into VSD installations.
Would I be right in supposing that the semiconductive screens will present a higher capacitance path between phases and earth, and therefore conduct a greater amount of high frequency current? What is the effect on the inductance of the common mode return path?
