Urgent question to Abaqus
hungibst
KR
Dear Brothers,
I have installed Abaqus 6.81 without any error. However, when I finish a model, by following the Manual, I use " data check" from Job module. It shows " Submited" infront of Job module and the " continue" option is disabled.
I would like to upload the picture of my problem in the hope somebody could help me solving this problem for analyzing the model.
Many thanks,
Hung C. Le
Has the datacheck finished? You won't be able to submit the job until it has...
Martin Stokes CEng MIMechE
I done all the steps like manual of Abaqus.
I finish this step, data check, firt. But, it does not automatically change the status, from check submited to submited. I do it manually, submit. Even I used example file from Abaqus, the problems are similar.
I do not know, what the problem is.
The job status should be visible in the Job Manager. What does it say for the job you've submitted for datacheck?
I'd also check the jobname.sta and jobname.log files - they should be in your ABAQUS working directory. These will tell you if there are any problems with the job.
Dear Martin,
Thank you very much for your answers,
I found the error due to the making of different working directory location. It should be default for ABAQUS to run properly, and we should not change anything, which provided by program as well.
Hung C. LE
