Update icon 1
TDEtechnologies
27
In an assembly with several configurations, all works good , but in one pârt there is still the update icon, but when we push the update button, the icon is still there.
how is this possible ?
greetz gregory.
Yes, but there are some feutures in rolback state, but they where put in rollback automatically
how come ??
This typically happens when a rebuild is interrupted. Refer to Help > Index > rebuild, interrupt. An interruption can be caused by pressing the Esc key or when an error is found.
Which option is set at Tools > Options > System Options > When rebuild error occurs?
See Help > Index > rebuild, errors for more details.
[cheers]
"Which option is set at Tools > Options > System Options > When rebuild error occurs?"
This option was set to "Stop", now we put it to "continue" and it works.
Thanks CorBlimeyLimey
You're welcome.
Be aware though, that by allowing the rebuild to continue means that the parts which are causing the original problem are not getting fixed and could cause other problems later.
[cheers]
SW07-SP3
