I am making a 16 dp 44 tooth gear on a Barber C #12. I have set the hob slide to 1 degree 47 minutes as is printed on the right hand hob. When I cut towards the spindle I do not get a zero helix. The rough cut had a helix of about .020 per inch. The finish cut did not have the same helix. is was closer to zero but not zero. This machine is new to us. We have some some worn keys but nothing that we think can cause this. We are beginners so your answers for this may be simple. I would also say we have the book for this machine and have the 4 change gears that the book recommends for 44 teeth. We counted the teeth on each gear.
