Alf238,
To point you closer, use Direct Modeling - Move Region. Select the inside of the hole as the "seed face" and the adjoining faces to the one the hole is thru (not the intersecting face) as the "boundary faces". Then, you can use either vector or point to point for the move. It's a very cool tool though somewhat limited if your model gets complex.
Bill
