AskSymbThreadParms - unknow feature type
niedzviedz
PL
Hello
I have journal to color all cylindrical faces which are part of thread feature. Everything works perfects on NX12. When I switch to NX2007, it's stopped working. I receive information:
Code:
NXOpen.NXException: Unknown feature type in NXOpen.UF.UFModl.AskSymbThreadParms(Tag thread_obj_id, SymbThreadData_parameters)
in line
Code:
theUfSession.Modl.AskSymbThreadParms(myFeature.Tag, myThreadParameters)
Does anybody have idea how to solve it?
With best regards
Michael
From the NXOpen documentation:
NXOpen Help said:
Overview
Get parameters of a thread feature.
IMPORTANT:
"NXOpen.Features.Thread" classes have been introduced in NX1926 to create, edit and query threads.
Thread feature use thread standard file from environment variable UGII_THREADED_HOLE_STANDARD_DIR for features
created interactively or using thread NXOpen classes in NX1926 and later.
UF_MODL_ask_symb_thread_parms() will get parameters of pre-NX1926 thread feature or which are created using UF functions.
Otherwise it will return an error.
It sounds like if the thread feature was created (or "renewed") in NX 2007, you will need to use the new thread functions to query it.
www.nxjournaling.com
Yeah, they added the whole symbolic thread stuff into the "modern" NXOpen, while simultaneously obsoleting the old C function wrappers back in 1926 or so. This function will now only work for the old pre-1926 holes.
You'll have to re-record/rewrite the Journal using the "modern" functions, specifically the NXOpen.Features.ThreadBuilder class.
Thanks for the answer. I looked into documentation about NXOpen.Features.Thread, but there is not much there about it.
Below is my old code:
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module1
	Dim theSession As Session = Session.GetSession()
	Dim theUfSession As UFSession = UFSession.GetUFSession()
	Dim workPart As Part = theSession.Parts.Work
	Dim lw As ListingWindow = theSession.ListingWindow
	Dim displayModification1 As DisplayModification
	Dim facecolor as integer = 163
	Sub Main()
		lw.Open()
		Dim threadFeatures As New List(Of Features.Feature)
		Dim threadFaces As New List(Of Face)
		For Each myFeature As Features.Feature In workPart.Features
			If myFeature.FeatureType.ToUpper = "SYMBOLIC_THREAD" Then
				threadFeatures.Add(myFeature)
				'lw.writeline(myFeature.tag.tostring)
			End If
		Next
		Dim myThreadParameters As UFModl.SymbThreadData
		For Each myFeature As Features.Feature In threadFeatures
			try
				Dim threadedFace As Face
				threadedFace = Utilities.NXObjectManager.Get(myThreadParameters.cyl_face)
				threadFaces.Add(threadedFace)
				Catch ex01 As NXException
					If ex01.ErrorCode = 512008 Then
					Else
						'lw.WriteLine("error: " & ex01.ErrorCode & ", " & ex01.Message)
				End If
			end try
		Next
		displayModification1 = theSession.DisplayManager.NewDisplayModification()
		With displayModification1
			.ApplyToAllFaces = False
			.NewColor = facecolor
			.Apply(threadFaces.toarray)
			.Dispose()
		End With
		lw.Close()
	End Sub
End Module
With best regards
Michael
