Unnecessary lines in drafting
venomex
Automotive
IN
Hi all,
I was creating a drawing of an assembly in NX. The Jt part in assembly when projected as a view shows multiple lines on surface by default making the part as black object while other NX parts are visible clearly like they should.
Any solution?
Shetty,
Newbie
Using NX 10.0.1.4
And also is there a way to hide the extra lines or show only boundary/ outermost shape without inner contours of a part using render sets?
Shetty,
Newbie
Using NX 10.0.1.4
It seems like there is no way to fix the multiple line issue obtained while using render sets by using a jt file. There is no problem while using the NX part file except for loading times.
And I figured the solution to my second comment. It was the filters/checkboxes that I had to use present around hidden lines option in render sets.
Shetty,
Newbie
Using NX 10.0.1.4
