Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
To clarify my thought pattern on this, I refer to "inward" as relative to the surface indicated, thus inward on the surface of a hole would make the hole bigger, because the direction is toward the material; same thing with "outward", which would make the hole smaller, being away from the material. Same intent, different symantics.the tolerance would then have to apply into the surface (0.000 outward)
