So long as both parts are modeled correctly with the appropriate units set, there should be no problems. The only time I've ever run into difficulties is when someone has simply accepted the default units setting for both types of model - then, of course, you wind up with one model that's 1/25th the size of the other. Just make sure the metric unit is done using the metric units settings and the inches are done to inches and you'll be just fine.
