Units for modal analysis?
  • Thread starter Thread starter soccer8888
  • Start date Start date
S
soccer8888
Guest
I've searched and looked, but can't seem to find what frequency units the modal analysis uses. I assume its hz, but can anyone confirm? Thanks!
Nobody knows?
I thought also it was Hz.
You have made correct assumption; modal analysis results are in Hz (1/s) - assuming that unit of your Pro/E system time is second.
Your can check your system units in Standard mode of Pro/E at Edit>SetUp>Units. Under Info... button you will find your Derived quantities which include Frequency.
Its in Hz only
Thanks guys!
