I have very little experience with the use of anti-washout admixtures but I would suggest that you check the compatibility of this product with other admixtures if applicable. Our firm performed some lab testing on such a mix. In that case, the mix was a proprietary product of the concrete supplier so I am not aware the mix details (proportioning, etc.). The mix included air entrainment. The air did not disperse well. At the request of the supplier, we performed linear traverse tests on samples and found that the spacing factor was way out of whack. Otherwise, the slump was as specified and compressive strength exceeded the project requirements.
