KOTOR1
- Jan 27, 2009
- 48
I have situation where a steel lintel (wide flange) supporting reinforced masonry is supported by a steel column in the middle due to the length of the steel lintel (steel lintel is continuous over the column). Will the column be designed with K=1 in both directions or should column be designed with K=1 in one direction and K=2 in the other?
My boss says that since the masonry is reinforced and is braced back (steel angle - 2'-0" above steel lintel) to the joists as well as designed for out of plane bending and braced at the top with the deck, K should be one in both directions.
