I have a drawing which has a assy procedure that was generated in Word. Unfortunately at this company certain note numbers must must be inside a triangle. What I have been doing is making a sketch of a triangle and moving it to encircle the note number.
I needed to make changes in the Word document, so therefore the triangle was no longer in the correct location. I moved the inserted document which allowed me to select the triangle and move it elsewere on the drawing. I reposition the Word document. Now I can not select the triangle. It is not located within any other view border, nor is it within the document window. I have tried Selection filters, but nothing will allow me to select the triangle. I can select everthing else but not that. I either need to move it or delete it.
Can anyone offer any solution?
