CivilSigma
- Nov 16, 2016
- 107
I am working on home gable roof repair in Canada in a very cold climate region.
The attic space had soffit ventilation, however the assigned contractor had insulated the attic space using spray-foam and covered up the soffit ventilation area.
So, now, I have an airtight attic space with no ventilation what so ever.
Is this a problem for moisture damage/ice damming on the roof? My thought is that if you assume that the spray foam insulation provides an air barrier and air-tight space performance, then I don't expect warm air to travel up to the attic space and cause moisture damage/ice-damming during the winter months. Would ventilation therefore be required?
Are there any references published on the performance of air-tight attic spaces?
Thank you,
CS
Thank you,
CS
