" expected this failure of the bolts."
Our experience list shows we have sold hundreds of this type mill over the years, from 2 or 3 domestic manufacturers, with no record of broken bolts.
We bought this mill ..wink.... wink..... "overseas" .
Their website says they have over 400 of this type mill in service.
The manufacturer said to an engineer who speaks their language that they had some bolts break "several years ago." I have asked several times via e-mail what caused those reported bolts to break, and received no reply.
What follows is a list of questions that I have I asked the manufacturer several times, and to date have received no reply.
1-The body of the one broken bolt we have is extremely rusty. I sent pictures and asked if they expect this level of corrosion in service. (Our metallurgist said the corrosion of the fracture surface was too rusty to analyze - sheesh)
2- The Washer under the nuts shows sign of minimal contact ( a narrow ring) with the mating part. The holes shown on the drawings for the mating parts would be appropriate for a 43 mm bolt, but a 39 mm bolt was used. I asked if they expect this narrow contact, how thick the washer is supposed to be, and what is the flatness tolerance for the spot face under the washer
3-We got a copy of the bolt drawing after the bolt broke. The material is nominally Grade 8/12.9. The assembly drawing for the factory assembled (over there) tube and bearing trunnions describes hydraulic tensioning to a value appropriate for a grade 2 bolt. I asked how the tensioning value compares to the working loads.
There are other issues with systems on this mill, and many, probably most of the replies to my technical questions have been similarly ..... disappointing. For instance, the mill is driven by a girth gear and pinion. The pinion is supported by SKF double row spherical roller bearings using tapered adapter sleeves drilled and tapped for hydraulic removal, mounted in mill manufacturer supplied custom pillow block housings and seals. The O&M manual has no lubrication procedure or maintenance schedule. We eventually got a procedure ( the bearing housings block the W33 groove and holes in the outer race) But the OEM's reply to my request for a lube schedule started with they would ask SKF, and recently ended with "SKF recommended twice a year, but it depends on rpm, service, etc." Well, the OEM designed the seals, so I'd guess after 400 mills they might have an idea how effectively they seal against dust and dirt in a typical plant, they designed the mill for a particular rpm, and with a customer base of 400 I'd expect they'd have a little feedback, and been asked this question before, or could go ask their largest happiest customers how often they grease the danged bearings.
So, I think when this mill was purchased a few years ago no one would have expected bolts to break. Today, I am not really surprised one bit.
