I know that modern formula one cars use fuel injectors mounted above the individual throttles that spray fuel directly down into the intake trumpets (I beleive they are called standoff injectors). This seems like it would be ideal from a fuel atomization/vaporization standpoint seeing as the fuel has the most time and space with which to mix with the air charge. Although direct gasoline injection is banned in F1, would they use it if they could?
I understand the ability of GDI to produce stratified A/F ratios and run lean without producing dangerous cylinder temperatures, therefore acheiving better fuel economy (like the audi R8 race cars for example). But does this ability come into play at WOT? I also understand the concept of acheiving greater VE due to the air charge entering the engine being pure air as opposed to an Air/Fuel mixture. Thus the engine is able to ingest more air for a given head flow rate, since the fuel is added later. However, during a WOT scenario given a high performance engine such as an F1 car, do these advantages outweigh the presumed loss of air/fuel mixing that a standoff injector would provide?
Sorry for the long-winded post. My basic question is this: Would F1 use GDI if they could and why? Thanks
