UG-79 minimum thickness after forming 1
MechDesign105
CA
Hi!
In UG-79, is the minimum thickness after forming supposed to be larger than the minimum thickness calculated?
Can the minimum thickness after forming be smaller than the one calculated?
I did not find this clear when reading the article..
Thanks!
Yes, the minimum thickness after forming shall be larger than the calculated minimum thickness, that's trivial. Which part of UG-79 suggested you the contrary?
Cheers,
gr2vessels
