Interpretation of UG-32(i) ASME F&D Heads
GinBread
It seems to me that the standard ASME F&D heads that most head companies offer, where the ICR = 100% OD, would violate UG-32(i) if you were to apply any amount of corrosion allowance to the head in your design calculations. Is my understanding correct? If not, could you please elaborate / point me to other parts of the code to justify?
UG-32(i) states:
(i) The inside crown radius to which an unstayed head
is dished shall be not greater than the outside diameter of
the skirt of the head. The inside knuckle radius of a torispherical
head shall be not less than 6% of the outside
diameter of the skirt of the head but in no case less than
3 times the head thickness.
Solution
See interpretation VIII-1-86-175
Question (1): Does a torispherical head satisfy Code requirements if the inside crown radius exceeds the outside diameter in the corroded condition but meets the requirement of UG-32(j) in the noncorroded condition?
Reply (1): No; see Appendix 1-4.
Question (2): If the answer to Question (1) above is no, which paragraph of the Code should the thickness of the torispherical head be calculated?
Reply (2): The torispherical head must meet the requirements of UG-32.
You've used a number of acronyms that may not be universally understood. Please detail them in your post.
You'll have to forgive me, but I don't particularly follow your point. Is there some math that you can detail out? What do you mean by "most companies"?
Solution
This pretty much straight up answers it. Thank you.
Sorry about that!
Here are the acronyms as follows:
F&D: Flanged and Dished
ICR: Inside Crown Radius, synonymous with Dish Radius (DR) in some catalogs
OD: Outside Diameter
The math as I understand UG-32(i) is just: ICR ≤ OD
And by most companies I mean that every single head manufacturer that I've come across that offers ASME F&D heads, from companies like Bethlehem Steel, Fort Worth F&D Head Company, Tank Components Industries, Paul Mueller Company, and so on all state that their "ASME F&D" heads are made to where the ICR = OD.
