Hello all,
Can someone give me a breakdown on the correct method for installing u-bolts? And what I mean by this is, my company has a standard detail for u-bolts that shows them being used as an anchor or a guide. Is it common for a u-bolt to be used as an anchor? I have only seen them used as a guide personally, so I am curious if using them as an anchor is a thing or if it is another practice that should be avoided.
And a follow up to that question. Say I have a pipe running underneath a beam with not enough clearance to use a hanger support. What are the cons of using a u-bolt on the underside of the beam rather than the top side?
Thanks,
DGrayPPD
Thanks,
DGrayPPD
