Typical corrosion allowances. 2
Petroleum
PT
Piping designer, based on service corrosivity, adds corrosion allowances to the calculated pipe thickness. In a new oil refinery construction project, which would be typical corrosion allowances?
Is there any rule to be followed?
Luis
From Chapter 20 of Norman P. Lieberman's Troubleshooting Refinery Processes (Penwell), which I recommend reading:
A corrosion rate which reduces a pipe wall to half its original thickness after 10 to 15 years is a reasonable target for common processes such as crude running, coking, fluid cat. cracking, gas plants, alkylation units, etc.
According to this criterion, for a CS pipe carrying high-sulfur diesel at 260oC with an original wall thickness of [¼] in. or 250 mils (mil = 1/1000 inch), a uniform loss of 10 mil/year would be OK. This rate can be known from previous (published) experience or measured with coupons, probes or suitable instruments. It means the corrosion allowance would be 12.5 years [×] 10 mil/year = 125 mils = 0.125 in.
There are many different causes and types of corrosion in a petroleum refinery. Each involves a different material wastage rate (not always wall thinning) which depends on the corroding environment (chemistry, hydraulics, temperature, pressure, etc.), the selected metallurgy, and even welding and other preliminary procedures.
For Carbon Steel piping in refinery service, a typical C.A. assumed and given will be = 1.5 mm (1/16"). In some extreme cases, a C.A. of 1/8" or 3.2 mm is given (but not as a general rule). For high temperature services on bottom cuts of corrosive hydrocarbon services should we use 6.35mm corrosion allowances?
From my search on this subject I suppose that there is no rule or recommended practice and the things are a little bit established ad hoc empirical based on licensors experience.
I think that actually in a new refinery construction a RBI approach should be made to define expectable corrosion rates then based on those expectable corrosion rates designer should add corrosion allowances with the following criteria: high corrosion rates high corrosion allowance, medium corrosion rates medium corrosion allowance, low corrosion rates low corrosion allowances.
Thanks for you sharing
Luis
BigInch, thanks. A big hand on your being elected TMW by the community.
Luis, creo que sus conclusiones son muy razonables.
