Two Phase Pump???
  • Thread starter Thread starter -
  • Start date Start date
Guest
Daer Gentlemen,
I would like to ask you guy that " Do we have any pump that can pump Gas & Oil in the same time?"
or "Do we have any compressor that can handle large quantity of oil?"
TDP = 300 psi
gas 75 MMSCF/d
oil 1000 BBL/d
How to transfer oil and gas in the same pipe line?
Some screw compressors could handle ratios like you propose, but there isn't any in the size and pressures you are looking for.
Seperate, compress/pump, and then recombine. You need to simulate the line in order to get the right line sizing for two phase flow. To large a diameter and the liquid phase separates and slugs, to small and velocities add to much friction.
Good luck
