Two monitors problem
blckwtr
204
I have just installed a second monitor in my office, and moved mathcad over to the second monitor. This is practical for many reasons. I can study a cad-file or a document simultaneously as performing calculations.
However, the toolbars is still "stuck" in the other screen, such that when mathcad is active, they are blocking for a document on the first screen...
Actually no...:) But here is one;
How do I move the toolbars to where they belong?
If you just can't change your process to run MathCAD on monitor 1 then I've found it best to just close the toolbars. Sometimes that is a pain, but usually it isn't a big deal.
David
It's probably for the best. I've becom enough experienced to know the most common "hot-keys" after all...
....thx....
I have noticed the same problem. I don't have a fix. I have a second monitor that I have rotated 90% so I can see more lines of code or text. The floating too bars stay on the main monitor. It is only a minor anoyance.
You should report it as a bug, if nothing else.
TTFN
FAQ731-376
If you make your second monitor the "primary" monitor then the toolbars will go on that monitor.... but that's the only "fix" I've found
