Twin Engine V12 or 2x60°V6 1
assquatch20
Industrial
Jun 30, 2017
11
I'm going to attempt to mate two modern FWD GM engines into a longitudinal V12. As the title states, they're 60° V6 engines that can be pretty easily setup for RWD applications. With FWD accessories, they should fit together tidily enough.
My understanding is dragsters coupled engines like this would two sprockets and a double strand chain, but I'm looking for something that'll last longer, and ideally I could decouple the front engine to run as a V6. The standalone tuning to allow this will be difficult. I've read of different options but perhaps someone here could recommend something. Ideally this coupler could fit 6 or 12 different ways to allow different timing combinations of the engines for testing. Any ideas for a reliable coupler/decoupler would be appreciated.
The balancers in these engines I need to learn more about, but I'm curious if you can eliminate the need for a secondary harmonic balancer if coupled correctly. Probably not worth pursuing in this case. Constructing an exhaust system that's capable of sounding like a balanced V12 would be nice. I'm honestly not even sure what effects aside from sound would be present, given the engines are each balanced.
The routing for coolant through two engines seems a bit redundant when I want to turn one off, but maybe possible still. I could eliminate one of the thermostats maybe or use an electric water pump on the dead engine to assist with this. Ideas here are also appreciated.
I've been told not to combine the oil system into one, and though I don't totally understand why not, it does seem safer not to.
What am I missing here?
I think a good question I should go ahead and ask to help with the balance thing is such: While a 90° V4 is inherently shaky I'm told, could it be on the nose of a V8 to only add power and balance to the two? Admittedly I don't know much about V4's aside from motorcycles and homemade projects from years ago, but it seems you could smoothen the NVH on a V8 theoretically by just having a properly timed V4 on the front of it. While this would be harder than what I'm trying to do as far as sourcing parts goes, it may help me better understand the fundamental harmonics at work here.
You want to couple the engines front to back (the flywheel end of one driving the front pulley end of the other)?
The front pulley connection is normally not designed to transmit full rated power of the engine. The rest of the crankshaft of the rear engine probably isn't designed to transmit the power of two engines.
The chain and sprocket method allows the flywheel end of both engines to do all of the power output without having to go through the front pulley. It also means the front end of each engine can operate all of its own accessories just like it normally does. It also provides some degree of "give" to allow for mechanical vibrations and torque fluctuations.
If you want to be able to shut one engine down, you will need a clutch to do that. There will not be any synchronization on re-engagement, nor does there need to be.
Keep it simple. Let each engine operate stand-alone completely independent of the other one aside from the throttles being mechanically connected. Each one is mechanically balanced on its own, each one does its own oil system, each one does its own ignition and fuel delivery.
A V8 + V4 probably isn't a good idea. A V8 has 90 degree firing intervals. An even-firing V12 has 60 degree firing intervals. A V4 with 90 degree bank angle and single crank pins has uneven 90-270-90-270 firing intervals. There's no way to stick that onto an even-firing V8 without resulting in uneven firing intervals without completely redesigning everything - which is, of course, the correct way to do what you are attempting to do as opposed to butchering something together that was never meant to work together ...
The engines would be rear to front. My understanding is tractor pullers and industrial hydraulic pumps may have couplers like what I'm after. Perhaps you could clutch the front engine and use the ignition system to bring it back in time. Unifying the exhaust and using that to each engine's advantage is part of the exhibition here, but running them separately is neat too.
The really terrible approach would be to spin the front engine dead for the sake of fuel economy, I'd think. Hence the idea to decouple. A somewhat efficient "sleeper" is part of the theme, I guess.
Coupling the exhaust system of a running engine to the exhaust system of one that's not running is a
>>>>>>>>>>>>>> REALLY BAD IDEA, <<<<<<<<<<<<<<
because the exhaust gases will destroy the idle engine's cylinder bores in a matter of hours.
The crank nose of a (sturdy) John Deere 6.3 liter Diesel is rated for something like 75HP @1800rpm. I assume that tractor pullers add extra keyways and/or shrink disks and/or custom cranks, and still don't expect much in terms of lifetime.
If you want a V12, just buy one.
Mike Halloran
Pembroke Pines, FL, USA
It's unclear what the original poster's objectives are. If the objective is simply "more power", that's what turbochargers are for. Or ditch the V6 and simply use a modern V8 like everyone else including GM themselves do. I'm not sure what two coupled V6 engines will do that can't be done with a supercharged V8 like the one GM supplies in some versions of the Corvette and Camaro, complete with a warranty.
"Because we can" ... sure, but not all ideas are good ideas ...
[wink] I'd rather dig a start digging a foundry with a shovel than buy a V12.
If it's that ill-advised maybe I should try to fuse two blocks together and make a crank. Seems like a breeze, no?
I worked on a supercar that was to have a V12. We couldn't get the sums to work unless we took the power off the middle of the crank, ie we effectively ran two V6s back to back. One trouble with trying to run them nose to tail is that the second crank is carrying twice the torque it was designed for, and another is that the torsional vibration resonances would be very low frequency. All of these problems are solvable, it just depends on your constraints and targets.
Cheers
Greg Locock
It would be best to have a special crankshaft made for the rear engine, like mentioned it will be looking at twice what
it was meant to take for torque.
Now this is an interesting idea. How did all the ancillaries work, and more importantly, how did the drivetrain all come together in this case? A V-drive or some sort of splitter or transfer case could be useful here maybe. The ability to split the power for all wheel drive while keeping one transmission would be dandy and could maybe be integrated in a tail to tail setup like this.
I think it was a chain drive to a transaxle, but might have been Mini style drop gears. Yes it was AWD. It never got much further than stroking the program manager's ego, but we did get some nice cars to play with.
Cheers
Greg Locock
I need to understand the architecture of this engine block better, but I'm starting to give in to the idea of cutting and welding two engines together, at least the blocks if not the heads, then line-bore and get everything squared back up. Actually cutting and welding this much material seems daunting, as I'm not sure what would be necessary, but I know it's doable for a one-off.
90 degree v12? Interesting. Nasty. But interesting. I suppose you could argue that two I6s intermeshed at any angle could work.
Cheers
Greg Locock
The V12 LS engine is part of my reasoning here, but I'd rather use the 60 degree engine and not cut right down the bore if I can help it. If I'm lucky with the coolant and oil galleys it may be feasible. GM was going to do this at one point but abandoned it, if I recall.
The idea of using the GM Atlas I6 to do a twin inline six has crossed my mind, but once again, I'd be unsure how to join them with the transmission. Probably easier to do reliably than my first idea, but very large. Great for a marine application. Maybe a landyacht, but the small v6 is what I'm still curious about.
Might Google GMC V12 which had one piece block and crank, the rest from the V6
Those GM 3.8 V6's are pretty amazing. The engine has a history that spans from the 60's to the early 2000's. GM sold the rights to Jeep then bought them back. They came up with the split pin crank that made it even fire and then went on to turbo and supercharge them. You can take the supercharger off of one of the modern L67's, add 20psi of boost with a turbo and be into the 400hp range at the crank. I put one in the back of a VW rabbit a couple years ago.
URL]
I think you need to make the front of the rear crank as strong as the back. I don't know if there were steel cranks available for these, but if so, maybe you could weld on a hub that would be big enough to transmit the power from the front engine to the back. Hell, they've done just about everything else with these engines, it can probably do this too.
As far as a longitudinal transaxle, maybe you could use the TH425. It will be the 90 degree bellhousing pattern, where yours is the 60 degree pattern (although it's a 90 degree engine)
Oh I missed the 60 degree part. The 3.8's are 90 degree. I think the 60 degree engines are the 2.8's, 3.1's and 3.4's, which came in dohc. But the 3.8 is the Daddy.
