Sorry im still stuck!!!
Tried going back to basics, created three simple solid protrusions and formed them into a local group. Entered the statements into pro program.
but it wont work, just produces two errors.
Ive copied the whole pro program, (showing where the two errors occur) see below...... can you see where im going wrong??
Many thanks
VERSION
REVNUM 164
LISTING FOR PART TEST
INPUT
include_prot yes_no
protrusion yes no?
END INPUT
RELATIONS
END RELATIONS
ADD FEATURE (initial number 1)
INTERNAL FEATURE ID 1
TYPE = DATUM PLANE
NAME = RIGHT
FEATURE IS IN LAYER(S) :
01___PRT_ALL_DTM_PLN - OPERATION = SHOWN
01___PRT_DEF_DTM_PLN - OPERATION = SHOWN
END ADD
ADD FEATURE (initial number 2)
INTERNAL FEATURE ID 3
TYPE = DATUM PLANE
NAME = TOP
END ADD
ADD FEATURE (initial number 3)
INTERNAL FEATURE ID 5
TYPE = DATUM PLANE
NAME = FRONT
END ADD
ADD FEATURE (initial number 4)
INTERNAL FEATURE ID 7
TYPE = COORDINATE SYSTEM
NAME = PRT_CSYS_DEF
05___PRT_ALL_DTM_CSYS - OPERATION = SHOWN
05___PRT_DEF_DTM_CSYS - OPERATION = SHOWN
END ADD
if include_prot==yes
add part prot
ADD FEATURE (initial number 5)
!*** ERR: no END ADD statement for ADD on line 0
INTERNAL FEATURE ID 99
GROUP HEAD
NO. ELEMENT NAME INFO
1 Name Defined
2 Features Defined
3 Construction Defined
NAME = SHAPES
FEATURE BELONGS TO LOCAL GROUP SHAPES
MEMBER OF A GROUP, NAME = SHAPES
LEADING FEATURE OF THE GROUP: ID = 99
LAST FEATURE OF THE GROUP: ID = 79
END ADD
!*** ERR: unmatched END statement encountered
ADD FEATURE (initial number 6)
INTERNAL FEATURE ID 39
PARENTS = 3(#2) 5(#3) 1(#1)
PROTRUSION: Extrude
NO. ELEMENT NAME INFO STATUS
1 Attributes One Side Defined
2 Section Sk. plane - Surface RIGHT of feat #1 (DATUM PLANE) Defined
3 Direction Defined
4 Depth Blind, depth = 126.501 Defined
SECTION NAME = S2D0001
FEATURE'S DIMENSIONS:
d1 = 177.36 (weak)
d2 = 15.68 (weak)
d3 = 77.20 (weak)
d4 = 126.50
END ADD
ADD FEATURE (initial number 7)
INTERNAL FEATURE ID 57
PROTRUSION: Extrude
2 Section Defined
3 Direction Defined
4 Depth Blind, depth = 108.892 Defined
SECTION NAME = S2D0002
02___PRT_ALL_AXES - OPERATION = SHOWN
d5 = 30.00
d6 = 93.26 Dia (weak)
d7 = 72.64 (weak)
d8 = 123.26 (weak)
d9 = 108.89
END ADD
ADD FEATURE (initial number 8)
INTERNAL FEATURE ID 79
PROTRUSION: Extrude
2 Section Defined
3 Direction Defined
4 Depth Blind, depth = 125.487 Defined
SECTION NAME = S2D0003
d10 = 60.00
d12 = 189.15 (weak)
d13 = 18.94 (weak)
d14 = 112.59 (weak)
d15 = 125.49
END ADD
endif
MASSPROP
END MASSPROP
