say I raised my static comp to about 20:1. I only let the intake open 1/2 the stroke time, close about 50* BBDC so I would only have half the cyl peak pressure. and more of an expansion rate.
so with this setup will this only work with a N/A engine?
Its a given that you would need a small, fast burn chamber.
Up the compression, reduce peak pressure, and increase the expansion rate.
have the exaust open about 10* BBDC.
by creating a more complete-faster burn, and more expansion, I will have recouped any power loss from having less air.? hopefully.
also the piston wont have to use so much energy to compress the charge with the higher comp ratio.
with the greater expansion rate the egt's will lower.
(sounds great except for any kind of lean burn you will have to increase the intake temp and or use a turbo.)
so how do incorporate a turbo with this?
