processeng01
- Nov 7, 2006
- 19
Dear all,
I would like to get your comments to the following:
ASME B31.1 mandates that downstream of a pressure reducing valve shall be protected either by i)designing the low pressure side same as high pressure side ii)or by installing a pressure relief valve with sufficient capacity.
Now, considering the steam surface condenser applications, we have typically single or dual bypass lines to the condenser in CCPP's. Typically there is no PSV located on bypass piping in most of the plants, so designers apparently rely on safety valve/rupture disk of condenser.
My question is as follows:
What do the condenser standards (such as HEI) say about how to size the PSV+rupture disk if there is a bypass line to the condenser?
My take is that we have to consider the case where bypass valve is stuck open and desuperheater is not working properly. This would correspond to worst case with high energy steam dumping into condenser. Is it too conservative??
Appreciate any information. Sorry for poor English
