I work at a DOT and we have thousands of poles supporting lights and signs. When I was in Grad School, we talked about using tuned mass vibration dampers to reduce vibration forces on structures. Our aluminum poles come with a device that sounds as if it may be one of these devices. However, our steel poles do not. I do not know why this is so.
I would like to do my homework first, and then propose that we install tuned mass vibration dampers on some of our larger steel structures to reduce the amount of loading on these structures due to wind. So far my research indicates we can resonably expect to reduct the base moments by 33-40% with this technology. It is extremely simple, until you have to do the math. Eigenvectors send a chill down my spine, but with the help of a well documented example, I could likely handle a two or three DOF model.
Is there anyone among you that can steer me in the right direction so I may master the mathmatics of this problem? Thanks in advance for any help you may be able to provide.
