Our welders have been TIG repairing damage (corrosion and physical) on some of our high, medium and low pressure process tubing, alloys welded were AA5000 series Al, Cres 300 series and Inconel 625. Fuilds are hydraulic fluid, and #2 fuel oil. They are certified for 1/8" plate SST and AL all position. They use the damaged area size dictates repair methods (metal build up, patch or section replacement). The tubing is test to the new tubing requirements (proof pressure test, flush, and systen checkout). They asked me to document the repairs w welding procedures.
I was thinking about
1. Remove tubing section
2. Clean
3. Repair (TIG) damged area governs repair method
a. Pin hole <.25" clad repair
b. area >.25" and <1/2 tube dia - over lay patch same thickness as tubing
c. area > 1/2 tube dia - cut out section to clean metal, replace removed section and butt weld
4. Pressure test
5. Flush/clean
6. Reinstall
7. Leak test system
What are other required parameters for this type of procedures or thoughts?
2. Clean
4. Pressure test
5. Flush/clean
6. Reinstall
7. Leak test system
