numberfive
Experts,
We have a non-asme stamped air-ejector condenser located at a customer's facility that has numerous leaks at the tube to tube sheet connections.
The tube attachment is nothing that I have ever seen before (see attached photo). I'm assuming that this acts as some kind of a compression fitting to create a seal at the tube.
Maintenance personnel at the plant tried to tighten several of these fittings in an attempt to stop the leaks to no avail.
Has anyone seen this type of tube to tube sheet connection before and if so what do you suggest to stop the leaks?
All leaks are located at the interface of the OD of the tubes to the ID of the threaded fitting to the tube sheet.
Thanks in advance for your insight.
numberfive
numberfive
