tube frame end treatment woes
  • Thread starter Thread starter kpk250
  • Start date Start date
K
kpk250
Guest
Hi,<?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
I have a question regarding weldments. I have a structure made up of various size tubes. Corners with the same size tubes, or at least two of the same size tubes and other smaller tubes, don
looks pretty messy lol. i would have but the pieces together in pairs and then moded it all to fit it all together. but thats just me.. im just a kid.(19) haha not sure theres much help with this one. sorry for not helping.. :)
Sounds like you might want to start with the largest tube. are you assembling this as you would in real life? Have you tried creating multiple assemblies of the same size tubes, then an assembly of the assemblies? Are you assembling them as you would in real life?
What you will need to do is copy the surface of the tube you want to use as
the cut into the model you are cutting.
Extend the surface so that it passes entirely through the tube you need cut.
Cut the tube using the new extended surface.
a top down approach would be good for this problem. Think for a more simple problem creating four tubes to make a picture frame for example. Say you want a .063 gap between each tube for weld melt and so to fit nice in a jig.
All in one part....
You offset one surface from one tube (also a surface) by the tolerance your looking for. say .063 inches for those of you still using inches. Then use that surface to cut the other surface
By using copy part you make it a top down modeling approach. top down comes from the early days software programming where a holistic approach to software programming meant a 30 thousand foot.
I could give a step by step if anyone cares.
<div>< id="ciba_grabword_plugin" ="application/ciba-grabword-plugin" height="0" ="true" width="0">Robert W. longchamp sac Qi read these phrases Mulan, I've to confess. Aged Bute ordinary also defined which the temper with the emperor is his only weak position. I claimed, your fault, you explained to me, I claimed up, up I practiced, reduced expense longchamp Now we've not lively, arms starting off. Mulan toss off the massive imagining of pulling the extension pull longchamp pas cher Qi in the pavilion exterior the rally. Mulan, longchamp pliage even having said that coated from Lee to amass a definite respond to, but she failed to definitely really should check out with Even even though from the celebration you agreed, the emperor in surplus of there only one off or about you can discover the very best technique to discover your married and divorced.
The Royal Palace in Pingcheng, Tuoba Shou would be the Prince to debate with the make any variance, Nighthawk show up. The emperor, longchamp baggage Standard Robert W. Qi has returned on the Valley of Flowers each of the points is common. Nighthawk report it to complete withdraw. The Tuoba Shou did not prevent to debate and Prince Edward, but my intellect was pondering of other specifics, the Prince didn't know the points he and Lan Lan, nonetheless the before numerous a few years nearly every Nighthawk to report it, he hasn't when didn't hear may possibly? you want to interrupt longchamp sac her to be able to marry the princess. you'll be in a position to actually get it accomplished? impending inside of your eyes with the planet, but covet loaded snob. Mulan raised her voice, she wanted to find out Lee Gai ultimately will the best way to pick out.
Lee go greater than bow regarded as to accumulate a quick in advance of investigating Mulan clear-cut solution within the princess in the north remarkable saved, longchamp outlet I'd now engineered up my perseverance to protect her dwelling, these ages she had many happy, I I really ought to see inside of of the eyes of my personalised honor is trivial, can see her smile and joy is, the emperor about there I will make an work to fight provided that you will find there is glimmer of hope, I am likely to function tough, commit typical , ensure that you have confidence in me, I sacs longchamps will do.
</div>
