I have a truss, with W14 (Flat)as chord members and TS5x5 as diagonals. Whhich of the following connection is better?
1.) weld a big gusset plate to the web of the W14. Slot through the TS5s and weld to the gusset.
2.) weld a WT to the web of the W14. (Stem of the WT welded to the web of the W14, Flange of the WT welded to the flange of the W14). Then weld all around the TS5s to the flange of the WT directly.
I feel like using the second approach because the web of the W14 is very thin. (3/8"
But the first approach is easier to fabricate.
Can anyone give me any advice? Or can you suggest a better
connection detail?
Thanks in advance for your help.
connection detail?
