I have a drawing that I am having trouble interpreting and was hoping that someone here would be willing to provide a sanity check for me.I have attached a drawing with the pertinent dimensions*. The drawing is intended to be interpreted per ASME Y14.5-2009. My concerns are as follows:
1. The 2x Ø0.375 holes call out a true position to A and B. This seems ok to me, except that there are no basic dimensions to go with this true position. Seems like the Ø8.500 B.C and 45° should be basic, correct?
2. The drawing calls out a true position for the Ø8.500 B.C. It seems like this is intended to locate the Ø0.375 holes, but those already have a true position called out. Am I looking at this wrong?
3. I am unclear if the Ø8.500 B.C. with the true position callout applies to the 1/2-13 tapped holes or not. The drawing would seem to indicate not, since the callout for the threads calls out a Ø8.500 B.C. on its own.
4. Anything y'all see?
*I cannot upload the actual print due to confidentiality agreements. The attached print also has modified dimensions and tolerances compared to the original, but should suffice as an example. This drawing does not include all dimensions, just the ones I thought pertinent. Please let me know if you believe that I failed to provide any necessary info.
